Root Phone stuck in boot loop after Safestrap install HELP!
So I rooted my Droid 3 and I installed Safestrap.apk
I had successfully installed a recovery as well as backed up the systemorig to my ext sdcard via safestrap in recovery. Then when I rebooted system the phone is now stuck in boot loop and won't boot into recovery. Can someone help?
In addition safestrap would not enable safe system, I toggled enable safe system but when ompleted the system was still disabled?
Just make sure your phone is not plugged in when you reboot.
I think #Code corrected that odd behavior when he updated SafeStrap from 2.01 to 2.1 - I thought it was kind of cool the way it worked before, but it did cause what looked like boot-loops.
I followed the directions but in bootstrap I do not have the option to install highlighted
Instructions are basically this:
- root the phone
- allow third party app installs
- remove Koush's bootstrap, if you have that installed already
- install the Safestrap app
- start the Safestrap app from the app drawer
- press the "Install recovery" button
- Allow the Safestrap app to have root permissions
- Restart the phone
[moved the thread to "All things root"]
