KSIXephos938
Member
Hi guys, my first post on here so hopefully this is in the correct forum!
Okay, so I've decided to flash a custom ROM (candy5 version 1.5.1) on to my HTC One XL (code name: Evita)
Being new to this, I had to unlock Bootloader on my phone and flash Clockwork Mod. I followed some steps on YouTube and everything was working perfectly up to this point. (One thing that might've been wrong now that I look back was that my Bootloader had ***TAMPERED*** on top of ***UNLOCKED***)
Not knowing that that might have been a problem, I went ahead and installed Candy5 version 1.5.1 (an unofficial build of Cyanogenmod 12) and Google Apps 5.x.x onto my phone. This was when the problems arose with both of them having "installation aborted" messages.
I decided to go on regardless and flashed boot.img from my PC using Command Prompt. It came up with two "OKAY" messages so I thought everything was alright. So then I rebooted my phone, and surprise surprise, it didn't work.
So I decided to do a bit of detective work and because I am a noob at this stuff, I clicked on Factory Reset on Bootloader and I wiped my whole phone.
That deleted my backup on Recovery and I now cannot access any files on my SD card as it comes up with the message "E: can't mount /SD card." I also cannot access my phone to make any phone calls etc. as I only have access Bootloader and Recovery and I cannot connect my phone to my PC.
So as you can see, I am in a bit of strife here and I now have a very expensive paperweight...
Any advice to, first of all, make my phone usable would be much appreciated. Furthermore, any information to make my phone run Andoid Lollipop 5.0.2 using a custom ROM would be awesome too!
Thanks in advance for all your replies!
It's 4 am here.
