ghnogueira
Hey there. I have my Galaxy S II (GT-I9100) for about a month, and since a couple of days ago it has been behaving very weirdly about USB and charging.
First of all, the phone thinks it has USB connected at all times. When I go to the settings menu try to enable mass storage it says USB is already connected, even though it isn't!!!
Sometimes when I start the phone it goes to that USB Kies screen and says "connected", when absolutaly no cables are connected AT ALL!!!
When I turn the cell off, remove the battery and plug it back in, without turning the phone on, the recharging battery icon appears, but blinks with a drained battery icon with a yellow exclamation sign and a thermometer which I sincerely have no idea what that means.
It also takes ages to recognize the power charger or when I really connect the USB cable. And finally, when I take them off, it also takes a while to "perceive" they're off and remove the charging lightning from the battery icons.
PRETTY PLEASE, SOMEONE HELP ME OUT, as I don't have time to take the phone to service, and didn't really want to do that
Thanks!!!
Thanks!!!
