Phone switches on but screen is blank
bluespud2
Hi,
I have a Huawei Ascend G300, bought 13 month ago. When I turn it on, all I get is a blank black screen. I know it has powered on because the lights on the buttons come on and it vibrates. It also responds to my login code and I can access it via usb, but the screen is blank. Anyone come across this before?
Any help much appreciated.
Did your phone get damp or wet? I had the exact same problem after mine did - the phone worked apart from the display. Turned out the screen connector to the main board had had a solder explosion, and unfortunately I had to get a new phone.
Hi,
I think that the problem is with the screen connetctors. So you'd better bring it to the service
