Root Phone thinks im using A2SD on ext when im not, why?
KingOfGreen
Android Expert
Sooo i had pretty much ran out of space for my apps with less that 20mb left. Even with move2sd since apps with widgets cant and others. Anyway didnt want to use darktremors a2sd script or a2sd, just to move dalvikcache to cache, so i did NOT partition my sd cards but i did move dalvik to cache. This gave me about 60mb of extra space so i moved a few apps back to internal storage like my browser so i could use them with usbms connected. While doing so i noticed in titanium backup it showed "SD Card (a2sd) 187mb/57.5mb free" so what is this and why is it showing as an sdext??? I even took my sd card out of the phone and all apps supposedly there worked just fine and ti still showed it the same. It still shows the phone and sd card storage perfectly normal. As far as i can tell everything works fine just curious as to whats actually going on
Took me a while, but its your /cache partition I believe, it sees where the dalvik is going, and logs it, when i wipe cache it changes that value. Seems to be a reporting bug with TI BU
Cool cool. Thank you. Do you by chance know the commands to move dalvik to cache without using that script? Theres just a whole lot of stuff there i have no intention of using.
the script does alot, it is the commands to move it, the script is made as to not break the phone, all it does is required.
What do you not intend on using?
Apps2sd or dalvik2sd, just moving the dalvik to cache freed up sooo much space. Dont need to use anything else. When i first moved it things seemed a little mixed up but it seemed to sort itself out over a couple days.
With everyone stressin about only having full memory and everyone saying how horrible it would be to to do app2sd (dont see why its such a problem really) just moving dalvik to cache frees up all the space they could need.
