Phone using wireless router.
D
datahogg
Guest
I am new to the LG L86C. (Show time).
Are there any other options other than Skype for using the LG L86c for phone
calls using a wireless hot spot such as my home router??
Does Skype work well with the LG L86C??
thanks in advance. H. Hampton.
I believe Vonage has an app that allows you to use your Vonage account for phone calls from your phone (using a wifi connection, including your own router).
