phone with a removable battery
I'm close to making a choice as to my first smartphone. thanks for answering my previous questions..... here is one more.
I think I want a phone with a removable battery so I can use an extended battery if I need to. I know the droid bionic and HTC rezound have removable batteries. Of those two, which is better? or, should I consider a different phone?
thanks
Stan
^He would appear to be on Verizon, which doesn't have an S2.
If I was a Verizon customer, it'd be a tossup between the Galaxy Nexus and the Rezound (this phone has gotten great user reviews), they both have removable batteries. The advantage of the GNex is Android 4.0, and the latest updates. It really depends on what's important to you.
The Rezound has a rep for horrible battery life so you will likely need an extended battery with it.
yes, a verizon customer. Is the removable battery important? or, am I worrying too much about this?
