SpannerMagnet
Hi guys,
I had a wee search through the forums but couldn't find a thread that highlights the same issue I'm having.
It started yesterday. I woke up and took my phone off charge. Even after I unplugged the charging cable the screen still displayed the message "Battery charged too 100%. Please remove charging cable". So I turned it off and on again. When it started up again I noticed that when the phone wasn't used and the screen dimmed down, it never fully turned off the display (unless I pressed the power button to lock the phone).
So I turned the phone off and removed the battery for ~30 seconds, popped it back in - and the phone was working normally.
So this morning I had the same issue...
I woke up, unplugged the phone and it still said "Battery 100% charged. Please remove charge cable".
So I turned the phone off and tried to turn it back on. But it will not start.
Even though no cable is connected, the phone still displays a charging icon.
As you can see no cable is attached.
I've tried swapping battery to a spare and I'm having the same issue.
Any ideas??
Thanks!
Any ideas??
Thanks!
