Hello everyone. I have an lg connect, i was wanting to downloading newer games on my phone which i couldnt get. So i decided to try and edit my build.prop(horrible mistake) and i copied the top row of a build.prop from a samsung GT-1900 and pasted it to mine. So i did a reboot and now it either gets stuck at the lg logo or it will go through the lg logo and then the screen will turn black(the phone is still on) and it will repeat over and over again. I have factory reseted,wiped EVERYTHING other than my sd card , no luck Please help. I would greatly appreciate it.
