I purchased a Samsung Galaxy A32 5g from Boost Mobile in Oct 2021, and used it with Boost for over 12 months. On Nov 24, 2022, I asked Boost tech support to domestic unlock the phone so I could switch to a different carrier. I met the free unlocking eligibility requirements, and I was told at the time that the phone was already unlocked. I trusted this, until the time came to pop in the new carrier's SIM card around Dec 6, when the phone told me it is still locked!
Hours on the phone over the past week with Boost tech support produced no results. I did get two tickets opened which were shortly closed without action because Boost support thinks the phone is already unlocked. On my end the phone clearly states that it is locked. If I go into settings > connections > more connection settings it says that the Network Lock Status is "locked," and if I try the new SIM I get a popup saying the phone is indeed locked and to contact customer support. I've tried the usual advice - put the Boost sim card in and wait, reboot the phone, shut the phone off for 60 seconds and then turn it on, perform a factory reset.
I've tried a third party unlocking service for $50 (The Unlocking Company) and they told me they can't give me an unlock code for this phone, and they wanted $65 more ($115 total) to send an unlocking kit. I said no to this and they told me the $50 will be refunded.
I'm pretty irritated because now I'm in the position of having to buy a new phone for the new carrier, and probably selling the old one, still carrier locked to Boost. A new, unlocked Samsung Galaxy A32 5g costs $279.99 when purchased from Samsung. Has anyone had a similar experience, or does anyone know anything else I can try?
I suspect the problem might be that the network is telling my phone that it can unlock, but my phone is not correctly getting that message for whatever reason. So maybe if there was some way to change the phone settings so it would get the message or forcibly "re-check" unlock status...
