Help phone wont charge
trauma145
well i was charging my phone and then when i noticed that the led was green i disconnected my charger and my phone turned off, now none of my charges will charge it, is there a way to fix it
If you can't charge the battery, put a different battery into the phone and see if it will charge. If that won't work use your insurance plan to have the phone replaced. Its either the battery or a hardware problem.
