Phone won't Ring
BPerth
Hi,
I have an Android phone I bought from china (need I say more!).
It was called a Gryphon, although dialing *#06# reveals 2 numbers:
imei1: 358809026445389
imei2: 358809026581753
These numbers reveal a phone, JINPENG S2000, that looks nothing like my phone and has totally different specs.
The phone I have has a 5 inch screen, 5 mp cam etc.
It actually works OK but has developed a problem, namely that it doesn't ring. During incoming calls the phone vibrates but does not ring. I've tried resetting the audio profile and restoring factory defaults.
Is there a way I can be sure about whether the problem is a hardware or software problem?
What else can I try to get it to ring again?
It's a pity. Apart from this it's not a bad phone.
Any helpful suggestions appreciated.
Thanks
BPerth
BPerth,
Probably already tried this but, have you tried changing your ring-tone? Also when you select a different ring-tone can you hear it(should play as sample). If not then what happens when you play music or video files, can you hear them?
