phone wont sync to computer
  • Start date Start date
A
Android Question
Guest
I have an android razor and it just stopped syncing with my pc. the cable I have work with all my other phones but when I use thm for the android it wont work. why is tht?
Go to Settings. Click on PC Connection. And from there you can select how you want your phone to connect to your computer. Hope this helps!
