Hello peaople, and thank you in advance for any help you may provide.
I have a Samsung Galaxy S Captivate and I recently installed a custom rom on (Omnirom for 5.1.1 Lolliepop).
It worked fine and the rom installed. then I went to install GAPPS to make google play work, I installed it seemingly without a hitch. but when I tried to install Apps I always got the error code 491.
I tried everything: Dumping cache for both phone and play store, removing and re-adding accounts,
nothing worked, so I decided to try and reflash back to android 2.1 Eclair using odin and a stock rom from samsung, I started the process and I didn't realize my laptop was low on battery.
Needless to say it died half way through and now the phone wont even charge,
so... My question is, any hope? at all?
sincerely, Toby.
again thanks in advance
sincerely, Toby.
