Help Phone won't turn on
abcd1234
The transform always seems to be a little slow turning on but today it just won't turn on at all. The phone seemed to be a little slower yesterday but nothing happened to it. I tried taking out the battery and putting it back and none of this has worked. Any advice? thanks
have you done anything at all to your phone? like flash a stock rom with custom recovery?
or is everything stock?
It just stays on the Samsung screen?
Then there are 2 things you can do (Both will factory reset the phone):
(Easiest Way)
-Boot to Recovery (Phone off> Press Volume down, Power, and Voice button [Under Power] then release the buttons when its turns on
-Scroll Down to Advance Options [Scroll With Volume Buttons]
-Then press the menu button
-Then click [Menu Button] on Wipe/Factory Reset
-Then Press Home
- When its done press back
-Reboot Options
-Reboot to System
This should work most of the time, if it doesn't then then do this:
-Download SWUpgrade, if you don't have it [Login] [You might need to make an account on SDX] [Reboot your PC when it's done]
-Download download Vampirefo's Kernel [if you want root] [kernel_recovery.tar] or Stock Kernel [Unlimited free file storage and free file hosting]
-Place the downloaded file in C:\Program Files\Samsung Electronics\SWUpgrade\Models\Binary (WARNING MAKE SURE NOTHING IS IN THIS FOLDER BESIDES THE FILE YOU DOWNLOADED)
-Open SWUpgrade
-Follow on screen instructions, make sure you have the driver for the phone.
Original Post:
Flash to Stock: STOCK Transform ROM: SPH-M920_MR1_DI11A_REL.tar
Root Samsung Transform: Guide to Flashing Vampirefo Transform Kernel and Recovery
Note the files provided are not mine they were made by Vamirefo and the people at SDX Developers
Hope this helps
