Hello.
Last night my charger wasn't working properly so I thought my usb port needed a change. But that wasn't to be the case since getting an original data cable it seems to be charging whilst turned off. Power button is not working. Usually after a certain amount of charge the phone turns itself on without pressing the power button but not, the battery animation is going in cycles instead of turning itself on. Can't reboot since the power button is not working so unable to select in recovery mode. So this is what happens (phone is turned off):
1) start of battery animation comes on
2) vibrates as the 2 part of the battery animation comes on for a second showing its charged
3) repeat
Not sure if this is a hardware or a software problem. Ideally I'd like to recover it without losing anything. Any solutions?
3) repeat
