Help Photo Sharing Between Devices
imaslomo
Hello!
I recently moved from a Windows 7 phone to Android and the thing I miss most is the ability to sync wirelessly my photos from my computer to my phone. Here is how I did it on my Windows phone:
1. I would go into Zune (the software used to sync the phone, similar to iTunes) and choose the folders from my computer to sync with my phone.
2. I would plug my phone into its wall charger and it would sync wirelessly every night when I charged it.
The photos would be synced to my gallery and I was able to see the photos even when I wasn't connected to my phone provider or internet.
Is there any way to do this on my new Samsung Galaxy S5? I attempted to copy my photos using the USB cable, but I didn't have enough room to move them. I had 16GB of storage on my Windows phone, the same amount as my Galaxy, and the photos fit on the Windows, so there is obviously some way to do it.
I can live without the whole no-internet or cell service needed to see the photos, but I would really love to be able to at least access my photos from my phone.
Note: in the gallery, if I scroll down I see a "connected devices" option, and underneath those devices (which are my home laptop and PC) there is "no images" listed. How do I get photos shared between these connected devices?
Thank you so much!
The reason it was so easy for you to sync your windows phone was because it had "windows OS" just like your computer. Android is kind of different, you will need to use an app to do this.
You can use dropbox, though you will need a monthly subscription for larger amounts of storage.
