PHP or JSP(server side) and Java-Android(Client side)
  • Start date Start date
A
Android Question
Guest
I know a little java, android languages.
Now I want to build an Android server-client application and for client side I will use Android(java) and for server side either JSP/servlet or PHP.
So I have 2 questions:
1)What is easier and faster to learn PHP or JSP/servlet(also don't forget that I also know java)?
2)Which one would work better? as the client side would be written in Android(java) may be the JSP/servlet would work better, or it doesn't matter?, and as PHP is the most used server language may be it would work better?
Thank you in advance.
