Help Physical and normal keyboards not working
Bereneth
1
0
Dear all
The problem has started about 2 two weeks ago: Sometimes I can't write anything with neither the physical nor the normal keyboard. I can press all the buttons but nothing appears on the screen. If I then change to another app and wait and then go back, sometimes it works and sometimes it doesn't work again. I have restarted my phone several times since the problem occurred for the first time but it hasn't solved the issue.
Has anybody experienced the same problem or know how to solve it?
Thank you very much in advance
BR
Bereneth
BEST TECH IN 2023
Smartphones
