bfldworker
Has anyone used Pimp my ROM before? And will it work with the Marquee and the custom ROMs available for it?
does rom manager work on lg marquee
Sure. I have the following tweaks selected:
WIFI connect speed
CPU Governors tweak set to InteractiveX
Disable I/O stats
Scheduler Systctl tweak
Disable Vsync
Ext4 file-System tweaks
Zipalign all APKs at each boot
Battery savings
Dialing-time tweaks
Quick Power-on
NOTE: I have a few more set but this is a good start. Keep in mind that what works for me might not work for you and NOT to set all of these at the SAME TIME. Select a few, reboot and run for a while then select a few more.
Boot time is a little longer too so expect that.
Duuuuuuude how do you do it! I set mine to 1400 and and the phone may as well have epilepsy! Not to mention I got a 1.5 star score when i ran the test! Does my phone just suck or do i just suck sad face
Some phones just can't handle 1400. You can play around with the I/O setting s and Gov settings. It may just be that the phone is not set up right. Try SIO and set you Gov to performance. If that doesn't work, set your I/O to NOOP and try that. Try a few settings. They may or may not work. You can also set your Gov to interactiveX and see if that will help.
EDIT:
Also, you may need to turn your phone up a little at a time. I had to do that for a long time. I would turn it up one setting at a time and run it for 5 or 10 minutes. When I first started overclocking my phone, it would lock up on me when I would turn it up all at once.
Hey Wetbiker,
Have you played with the VM Heap size for CTmod using this program? I am trying to squeeze ever picohz of performance from this from and I have heard that adjusting the VM heap size can help with multitasking.
Sent from my LG-LS855 using Tapatalk 2
Hey Wetbiker,
I am very interested in the megatron from BTW. I stole the boot screen from the Asus version tweaked the resolution and viola.
