AndroidHaCks
Check "Pimp My ROM" out on the play store. Numerous great tweaks and all are universal. I've tried most of them out and they haven't given me any problems and I can definitely tell a boost in performance
For the CPU controls use this:
https://play.google.com/store/apps/details?id=it.sineo.android.noFrillsCPU
Requires no permissions other than root access. No internet for shitty ads, none of that.
Does this app actually work, as in it literally overclocks? I heard that if the kernel doesn't support the app, then overclock/underclock apps are useless.
You might be able to change the governor though. Which can effect battery life.
Any changes made to /system, will not be reverted by a factory reset. Do if you boot loop due to a change to it, and have no adb, a factory reset won't fix it. It the nature of the beast modding without a custom recovery.
Can we use the kernel tweak for this device if not then its understandable. I dont need a brick on hand thats why im asking
