Help PIN entry instead of pattern
matzen
Is it possible to use a PIN entry instead of drawing the unlock pattern when I want to unlock my phone? It's becoming rather annoying having to draw the pattern every time...:(
It's not possible to use your pin, but you can turn off the pattern...the galaxy makes it difficult enough to unlock with that pesky hard button on the side, so u shudnt really need the pattern aswell!
