Help PIN Entry screen
Are you using a task killer? Have you rooted? Is it just random?
I never had it before I rooted and no every once in a while it will just reboot it's self, I also tried a task killer after root as my mate with a Desire would not shut up about one even though I dont think they are worth it. Anyway installed a TK and it rebooted my phone!
I'd say the same thing as powerkiter, after I installed a task killer it started asking me randomly (well it seemed to be random) from time to time. Often 2-3 times within a few minutes then I was fine for the rest of the day.
I debranded the phone yesterday and did not reinstall the task killer, no problem so far.
