Help pin lock
emburybrett
Ok... So i went out and got the RAZR Maxx when it came out and finally got my HTC thunderbolt to boot up (charger port needs to be replaced) and don't remember the pin code i have i have tried every thing i can think of...should i just do a reset since i going to sell it.
If you have no intention of using it, then yes. However if you have files on there you want, mount it to your computer via usb and remove your files.
