_Aardvark
I'm curious about the behavior of the S3 when using bluetooth and a phone that has a PIN lock.
My current phone (Droid X) has an option called "bluetooth bypass" that allows the voice recognition app to start even if the phone is locked with a PIN. Turning the bypass off (or using the phone before Moto added this feature) would prevent the BT headset from working.
This was a major headache before this was added, since I had to unlock the phone to make a call while driving (not so hands free). I used to have to keep the screen always on (to prevent the phone from locking) while driving which was a hassle and killed my battery life.
Anyway, what does the S3 do when the screen if off, you have a PIN lock screen, and activate the BT headset?
Also, is it s-voice that is activated on the BT button press?
