Pinch zoom problems and lag
Flex
Hi All,
Hoping someone can help with my query. It seems like my pinch to zoom is reversed. When I pinch, it zooms out, rather than zooming in. Are there any settings for this feature.
Secondly, I'm rooted, rocking modaco custom rom 2.9. The issue is, my phone still lags, I've got a good SD card and despite a massive improvement during the first few roms, but now experiencing lag sometimes.
Should I flash my old t-mob rom and re-root?
Hi All,
The pinch zoom works that way. If you think about it, your pressing two fixed points, and then dragging them together. The closer the two points are together, the small the image has to be to fit on the screen.
As for lag, I haven't tried the custom ROM, I am using the offical T-Mobile ROM and it works great, no lag whatsoever. Depends if you really need root or not.
