death2twitter
Are you on stock everything and want to help get rid of the signal fluctuations and Interface Shortage annoyances? No, this isn't some stupid petition, this is real.
I am currently in an email conversation with HTC tech support, and so far they've been extremely good. However, they asked me to perform a troubleshooting step which i cannot because I currently do not have acess to WiFi. Here is the relevant paragraph, copy-pasted from the email:
"I would like to enable an option on your phone as well. Let's navigate to Settings and tap on Wi-Fi to the left of the on/off toggle. Here we can press Menu>Advanced. I'd like to enable Best Wi-Fi performance, and for now at least set 'Keep Wi-Fi on during sleep' to always. Now let's return to Settings and, with only Wi-Fi enabled, turn airplane mode.
Let's hold down power for about 30-45 seconds until the phone powers off completely on its own. This resets the battery connection. Now let's press the power button and, once the screen has turned on, hold down Volume down until the phone finishes booting up. This disables third party applications and can help with testing. We should see Safe Mode written on the bottom left of your screen.
Michael, at this point if we turn off airplane mode do you get a good Wi-Fi connection? If so, does it act up after we re-enable mobile data?"
Basically, boot the phone into safe mode and see if WiFi fluctuates like the cell radio. Personally I don't see what WiFi has to do with it, but he seems to have a hunch, and I am more than happy to get one step closer to fixing this thing.
For me, nothing happened when I held the power button down for a full minute, so maybe shut off normally and pull the battery? Also, when I entered safe mode in airplane mode, it would not come out of airplane mode, so i had to re-reboot without airplane mode.
Bottom line, do what the guy says, and post results. Also, say if you had the same problems with the power button and airplane mode.
I don't want to make this sound like a demand, I am merely asking you guys, so together maybe we can get this thing fixed!
