I received a Pixel XL phone from a Lifeline company- no user manual, no charger, and as there were scribbles inside the box I'm guessing the phone belonged to one of their previous customers, so I'm even more concerned about security issues.
Initially, I noticed the photo section said 'no longer supported,' and there's no sound recorder.
When I checked system, it says there have been no updates- security or otherwise- since 2019. It also says the version is Android 10.
I am not tech-savvy. Is it possible to update/upgrade to a newer Android version- and, if so, is it free?
Any info or advice would be appreciated.
