On Android, I'm trying to perform some OpenGL processing on camera frames, show those frames in the camera preview and then encode the frames in a video file. I'm trying to do this with OpenGL, using the GLSurfaceView and GLSurfaceView.Renderer and with FFMPEG for video encoding.
I've successfully processed the image frames using a shader. Now I need to encode the processed frames to video. The GLSurfaceView.Renderer provides the onDrawFrame(GL10 ..) method. It's in this method that I'm attempting to read the image frames using just glReadPixels() and then place the frames on a queue for encoding to video. On it's own, glReadPixels() is much too slow - my frame rate is in the single digits. I'm attempting to speed this up using Pixel Buffer Objects. This is not working. After plugging in the pbo, the frame rate is unchanged. This is my first time using OpenGL and I do not know where to begin looking for the problem. Am I doing this right? Can anyone give me some direction? Thanks in advance.
public class MainRenderer implements GLSurfaceView.Renderer, SurfaceTexture.OnFrameAvailableListener {
public void onDrawFrame ( GL10 gl10 ) {
//Create a buffer to hold the image frame
ByteBuffer byte_buffer = ByteBuffer.allocateDirect(this.width * this.height * 4);
byte_buffer.order(ByteOrder.nativeOrder());
//Generate a pointer to the frame buffers
IntBuffer image_buffers = IntBuffer.allocate(1);
GLES20.glGenBuffers(1, image_buffers);
//Create the buffer
GLES20.glBindBuffer(GLES20.GL_ARRAY_BUFFER, image_buffers.get(0));
GLES20.glBufferData(GLES20.GL_ARRAY_BUFFER, byte_buffer.limit(), byte_buffer, GLES20.GL_STATIC_DRAW);
//Read the pixel data into the buffer
gl10.glReadPixels(0, 0, this.width, this.height, GL10.GL_RGBA, GL10.GL_UNSIGNED_BYTE, byte_buffer);
//encode the frame to video
enQueueForEncoding(byte_buffer);
//unbind the buffer
GLES20.glBindBuffer(GLES20.GL_ARRAY_BUFFER, 0);
//Create the buffer
//unbind the buffer
