A
Android Question
Guest
Hello friends,
I need some advice. I have a rooted nook running Cm 10.1.3 that has worked great without a hitch for about 8 months but last week my play store said can't connect with the retry button underneath. I read several of the forums and tried erasing the cache, turning off and on, etc. then I tried the last resort of erasing all data so as to start from scratch. When my device came back on everything was back to square one and worked fine EXCEPT now my play store is gone and there is no market place app either!
I tried downloading both manually onto my device but the market place app will not downlpad because it says not compatible with my device and the play store crashes immediately after opening.
What can I do? Do I need to re-root? I am at a total
Loss
Loss
