playing audio in directories
hakelm
I have copied parts of my music library to the SD-card in my Android. Now I would like to play the audio files in a directory and its sub directories preferentially just by tapping on the directory in file manager.
How do I accomplish this.
Thanks in advance
H
Thanks, but that doesn't seem to do the trick. It won't play a directory containing only audio files.
H
using Galaxy A3 with Android 8.0.0
Thanks in advance
H
I'm pretty sure the stock Samsung file manager app won't do that. Suggest you use a music player app that has a file browser in it. I use Foobar2000, and that can do that, i.e. play the audio files in a directory with one tap.
