Help Playing music thru car's audio system
joel745
My Maxx is paired to my Genesis and never had problems plying music thru my audio system without the need for a usb cable. A simple procedure, hit playlist and start a track, then hit cd/aux on the radio and the music would stream. I did factory reset loaded up the playlist but no longer can stream it into the car, I did this once before without a problem. Is there something I need to enable on the phone that I'm unaware of?
Is the car still paired to the phone? (A factory reset resets pairing.)
Yes it is, both incoming and outgoing calls work just fine, my contacts get updated as well. I had done factory reset once before with no problems of playing my music then, nor did I have a problem with my previous smart phone. I may charge up old phone (not activate for calling) pair it and see if it still plays music, I'm stumped.
