I have two frustrating problems, and I've scanned this forum and Googled around and didn't find any mention of these...
I have a Samsung Vibrant with Android 2.2
I use MediaMonkey (3.2.5) for all my music
1/ Whenever I copy playlists to my phone using MediaMonkey synchronize, the music copies fine, and the playlists seem to copy ok too, but when I use a playlist, it will only play the first two songs, and then endlessly repeat the second song in the playlist.
* It doesn't matter how many songs are in the playlist.
* It happens with all the playlists.
* The only thing I can do to fix it is to create a new playlist on the phone and add the same tracks to that playlist.
* If I select some other song in the playlist to play it will play, and then the second song in the playlist will play repeatedly afterward.
2/ The sync only works right the first time. If I add/delete songs in MediaMonkey and then sync again, ALL the songs get copied to the phone again (creating duplicates) and the the phone's media player crashes whenever I try to play any of the duplicated songs.
I would love any help anyone can give.
Thank you!
Thank you!
