A
Android Question
Guest
hi I use an Xperia Z and when I open playstore it says "playstore needs to enable backround data to be enabled" then gives an "enable" option then I click on that, it displays a list of apps and a sync checkbox which is checked, but from there I cannot do anything cause theres no option once this pop up window is opened, so I cannot use playstore. Please help urgently.
Thanks you
Thanks you
