*********Please APPLICATION Help***************
Lowrider1
I accidently deleted a widget or app off my home screen. I don't know the name of it. It allowed me to display my signal strength, battery level, time and date. BUT,,,When i touch the battery icon, for example, it would launch an app. Touch date, It would launch another app. It was my favorite app! I know it now, since i lost it. WILL TRADE KID'S! LOL TIA :)
Just add it back to the screen. Go down the list of available widgets and see which one is the most likely one you're looking for. If it's not the right one, delete it and go down the list again. Lather rinse repeat.
Long press an empty spot on the home screen, and hit Add Widget. As long as you didnt uninstall the app (which it sounds like you just removed it from the homescreen) then it should be in there.
I tried that before i posted, i guess its not a widget. but it acts like a widget. i looked at all my app's. i got too many, don't know what half of them do. haha I read EVERY post in this thread. i hope i don't have to do it again. it is a greaaat thread, it took me 2 month's. lack of available time. thx for your suggestion's. :)
TCAT, I don't think so. I haven't heard of either. I guess I'll go thourgh all my app's next. hehe thx :)
That kinda sounds like Widgetsoid mixed widget, but I'd suggest to just make a blank screen and test all the widgets you dont recognize on it till you find the correct one. LOL.
