kelvinblade
i'm recently out of a job and haven't been able to find a new job.
i'm thinking of learning to write apps for a living.
i don't really have any programming background but i am a quick learner.
i have some questions and would really really appreciate if you guys can help me out a bit.
1) i've read that the best way to go about learning to write android apps is to learn java first. is that true? how steep of a learning curve is it?
2) i've looked into MIT App Inventor, Illumination software creator and PhoneGap which uses javascript and html. How are they compared to the traditional way of coding using Eclipse? What are the limitations of each and which ones do professionals use?
3) do you guys think it's better to start off taking projects and writing apps for others before starting to write my own apps since without a killer app, its hard to get much revenue from ads. i've also been told that ios app makes more in terms of revenue than android apps, is that true?
i actually have a ton more questsions but if you can help me with these first and get my started, it would be great. thank you all so much in advance.
