Hi. I would like to seek help or suggestions regarding the issue with my newly bought SD card.
My phone is a Huawei Y7 Pro 2019 and I bought a Sandisk 128GB SDXC card for additional storage capacity.
So, what I did was I immediately mounted the card in my phone to check of course, thinking it's compatible since stated in the specs that my phone accepts SDXC cards. My phone prompted that the SD was "Low Level", I just ignored that since that happened many times already with other sd cards i owned and it worked fine.
After that, I ejected the SD and plugged it in my laptop so that I can copy my files from my old SD (Sandisk 32GB) to the new one. Upon mounting the new SD card again in the phone, it showed that some files got corrupted/missing. I ejected the SD and reformatted it in the laptop using a card reader, but after that it wont read/detect in my phone anymore.
I've tried to fix it by doing these:
- Wiping/cleaning the actual SD card
- Fix by CHKDSK and via CMD
- scan for and attempt recovery of bad sectors
- Changing the Drive Letter
- Reformatting it again using the SD Formatter, even formatting it in overwrite mode
- Tried formatting it to FAT32 using Tokiwa Fat32 Formatter, hoping it won't read because SD is in exFAT, but still, it didnt work.
I also tried mounting it to another phone, but still it was not detected.
The thing is, it is readable in my Laptop so I know it's not broken. Finally, I installed the exFAT/NTFS for USB by Paragon and connected the SD to card reader and then to my phone via OTG and amazingly it got detected. I was not able to mount it because it is a premium feature but it just confirmed that the SD is really still working.
Is there any way I can still use this SD card in my phone without using the card reader or even paying for the app? Or is it hopeless?
Thanks in advance!
Thanks in advance!
