Help Please help: Cannot connect to WiFi
Izene
Hi, this is my first post :)
I use to be able to connect my Ace to my WiFi but ever since I updated it from 2.3.3 to 2.3.5 I cannot connect to my WiFi.
It asks for the password,which I inputed, then it goes into the authentication and disconnects, then it repeats the authentication process over and over.
I have tried the Factory reset and the 326 one as well and no luck :(
I have also searched all over the forum and still no luck.
Please help me.
Thank you and have a nice day
And on an unrelated matter, anyone know any official,legit roms I can download?Or does it not exist yet? thanks
Hi There
my router was set to B/G/N mixed I changed it to B/G mixed, then problem solved. hope it helps.
cheers:)
