Root please help, cannot get into custom recovery..
I found a post saying to pull the battery, which I did, and it worked. But the problem is that I once I boot back into the ROM and then power off and try recovery again, it doesn't work. So you need to pull the battery every time?
stock, does that matter? That was honestly the last thought that crossed my mind, but I haven't had a chance to change to a different rom yet.
It does matter because some roms have an andvanced power menu which will allow you to poweroff your device straight to the recovery.
But i think there is something you can flash to obtain the power menu while still on stock
