Root Please HELP!?!?!?!? Cant Flash ROM
Okay, so i rooted my Samsung Galaxy Precedent, and then i flashed the ROM, successfully ran AreaRom 2.3, then i wanted to flash back to stock ROM, so i followed this post h tt p:// android area51 .co m/sa msung-ga laxy-precedent /idiots-guide-so-you-broke-your-precedent/ and its back to stock, now i want to reinstall AreaRom but when i go into recovery mode, the only options i get are, Reboot System Now, Apply Sdcard:Update.zip, Wipe Data/Factory Reset, and Wipe Cache Partition! PLEASE HELP ME! I need "Install From SD Card"!:(:confused:
Flashing back to stock flashed ur recovery back to stock
Re odin arearom 2.3
Then go from there
Follow my post under cyogen mod 7.1 on androidarea51.com it will set u up good. Its a realy indepth how to
