Root Please help!! Cant mount cache recovery log
I tried to install req's kernal and recovery so i can install the lunar-gen rom but it just kept vibrating, freezing, and then it just shut off. I then tried to back to 5.0.2.7 CWM and i did but still came up with the error E: /cant mount/cache/recovery so then i took out my sd card and put into my PC to format it and then put all the files back on which worked for me last time but now it just comes up with the same error. What can I do?
