bigmike20vt
Hi
I am pannicking a little as my wifes phone may be bricked.
i have just got a sim free prada 3 to replace her orange snafrancisco. I flashed using the official ics rom (foolishly i did not check the new phone before hand).
on putting the orange sim in, I get no signal, and when i try to select a carrier i get the error your sim will not allow a connection to this network.
I phoned orange and they were unable to help. they said i needed to return the phone as faulty. Maybe it is, but i cant help but feel it is most likely software somewhere.
i have done a factory reset ad enabled 2g only which the orange guy reccomended to get working.
i have noticed there are no settings in the apn section. i do not know if this matters. any thoughts so gratefully recieved.
cheers
cheers
