Help Please help, is there any way to turn off gracenotes?
lotsofjam
This, stupid application that runs along side the stock music player is driving me insane. Every damm time I put music on the phone with the CORRECT album artwork, this damm thing downloads some others and replaces them. Can it be turned off?
Right, just incase somone else runs into this problem, I have figured it out. You can disable it by telling it to look for album covers and when it runs, drag down the notifications menu, tap its progress bar, then it will ask you if you want to turn it off. I really hope there will be a way in the future to totally disable it
