Root please help.low memory keeps popping up..
Did you create an sdext? Which kernel did you use? How big did you make the sdext?
Sdext.no.I used the katokernel-ext.basically what i did earlier was partition SD card.picked 10-- the 1g one and then while in recovery I did USB mount to copy things back to SD card but computer didn't pick up SD card.also tried card readerand still same thing.can u please let me know what to do
.thank you
So, what you're saying is you partitioned it in cwm, selected 1024 (1gb) and the card no was no longer readable?
If that's the case I would suspect the partitioning failed some how. I would try to partition it again.
Yep. 1024 and 0 for swap (assuming u don't want to use swap)
Edit - the fact that it booted with katokernel-ext means that the sdext was at least created and mounted. If not it would have boot looped. But still, something must have gone wrong... you should have been able to access the main part of the card
Thank you partition it again and worked this time..thank u approach for helping.one last question is cm9 stable yet.does wifi work.camera.internet?
Camera does not work and likely never will. We simply do not have the drivers to make it function. Everything else should be functional.
