Help please help, main launcher problem
endrialb
hi everyone. my admire is rooted and i deleted the main launcher and installed prolauncher, but tonight i did a factory reset thinking that it will add all the programs back, but everytime i turn it on, i get a black scree, it tells me to force close the program. i can see the scrolling unlock switch. is there anything i can do?btw my brother has an admire as well, maybe we can do smth.
thanks in advance
By Factory reset ,The data and cache are formatted .When you get Root privileges you modify /system .
You have two options :
A)Flash stock ROM to restore the factory default
B.)First get a launcher installed on the phone .
Download Launcher Pro apk from their website and keep it in C:\
LauncherPro
you need to have android sdk installed
Perform C:\Android\platform-tools>adb install C:\LauncherPro.apk (or whatever is the name)
Now you have a Launcher pro working so you can navigate .
Get the launcher from your brother's phone and paste it in you /system with adb push/pull or FileXpert /ES File explorer with root privileges .(which means you have to root the phone )
LauncherPro
thnaks for the quick response.just to let u know, i cant perform anything in my phone, i only see the status bar.
on the fisrt way, where can i download the stock rom and how do i flash it?
i started following method B, and i got stuck at performing C:\android\platform-tools\adb adn i see a lot a script, and then goes back to C:\Users\3ndri and i try to install C:\LauncherPro.apk and the file just opens ...
heres the cmd script
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\3ndri>C:\android-sdk-windows\platform-tools\adb
Android Debug Bridge version 1.0.29
-d - directs command to the only connected USB devic
e
returns an error if more than one USB device is
present.
-e - directs command to the only running emulator.
returns an error if more than one emulator is r
unning.
-s <serial number> - directs command to the USB device or emulator w
ith
the given serial number. Overrides ANDROID_SERI
AL
environment variable.
-p <product name or path> - simple product name like 'sooner', or
a relative/absolute path to a product
out directory like 'out/target/product/sooner'.
If -p is not specified, the ANDROID_PRODUCT_OUT
environment variable is used, which must
be an absolute path.
devices - list all connected devices
connect <host>[:<port>] - connect to a device via TCP/IP
Port 5555 is used by default if no port number
is specified.
disconnect [<host>[:<port>]] - disconnect from a TCP/IP device.
is specified.
Using this command with no additional arguments
will disconnect from all connected TCP/IP devic
es.
device commands:
adb push <local> <remote> - copy file/dir to device
adb pull <remote> [<local>] - copy file/dir from device
adb sync [ <directory> ] - copy host->device only if changed
(-l means list but don't copy)
(see 'adb help all')
adb shell - run remote shell interactively
adb shell <command> - run remote shell command
adb emu <command> - run emulator console command
adb logcat [ <filter-spec> ] - View device log
adb forward <local> <remote> - forward socket connections
forward specs are one of:
tcp:<port>
localabstract:<unix domain socket name>
localreserved:<unix domain socket name>
localfilesystem:<unix domain socket name>
dev:<character device name>
jdwp:<process pid> (remote only)
adb jdwp - list PIDs of processes hosting a JDWP transport
adb install [-l] [-r] [-s] <file> - push this package file to the device and i
nstall it
('-l' means forward-lock the app)
('-r' means reinstall the app, keeping its data
('-s' means install on SD card instead of inter
nal storage)
adb uninstall [-k] <package> - remove this app package from the device
('-k' means keep the data and cache directories
adb bugreport - return all information from the device
that should be included in a bug report.
adb backup [-f <file>] [-apk|-noapk] [-shared|-noshared] [-all] [-system|-nosy
stem] [<packages...>]
- write an archive of the device's data to <file>
If no -f option is supplied then the data is wr
itten
to "backup.ab" in the current directory.
(-apk|-noapk enable/disable backup of the .apks
themselves
in the archive; the default is noapk.)
(-shared|-noshared enable/disable backup of the
device's
shared storage / SD card contents; the defau
lt is noshared.)
(-all means to back up all installed applicatio
ns)
(-system|-nosystem toggles whether -all automat
ically includes
system applications; the default is to inclu
de system apps)
(<packages...> is the list of applications to b
e backed up. If
the -all or -shared flags are passed, then t
he package
list is optional. Applications explicitly g
iven on the
command line will be included even if -nosys
tem would
ordinarily cause them to be omitted.)
adb restore <file> - restore device contents from the <file> backup
archive
adb help - show this help message
adb version - show version num
scripting:
adb wait-for-device - block until device is online
adb start-server - ensure that there is a server running
adb kill-server - kill the server if it is running
adb get-state - prints: offline | bootloader | device
adb get-serialno - prints: <serial-number>
adb status-window - continuously print device status for a specifie
d device
adb remount - remounts the /system partition on the device re
ad-write
adb reboot [bootloader|recovery] - reboots the device, optionally into the boo
tloader or recovery program
adb reboot-bootloader - reboots the device into the bootloader
adb root - restarts the adbd daemon with root permissions
adb usb - restarts the adbd daemon listening on USB
adb tcpip <port> - restarts the adbd daemon listening on TCP on th
e specified port
networking:
adb ppp <tty> [parameters] - Run PPP over USB.
Note: you should not automatically start a PPP connection.
<tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1
[parameters] - Eg. defaultroute debug dump local notty usepeerdns
adb sync notes: adb sync [ <directory> ]
<localdir> can be interpreted in several ways:
- If <directory> is not specified, both /system and /data partitions will be u
pdated.
- If it is "system" or "data", only the corresponding partition
is updated.
environmental variables:
ADB_TRACE - Print debug information. A comma separated list
of the following values
1 or all, adb, sockets, packets, rwx, usb, sync
, sysdeps, transport, jdwp
ANDROID_SERIAL - The serial number to connect to. -s takes prior
ity over this if given.
ANDROID_LOG_TAGS - When used with the logcat option, only these de
bug tags are printed.
C:\Users\3ndri>C:\launcherpro.apk
C:\Users\3ndri>
No not just adb .The whole command as a one.
Copy the LauncherPro.apk to C drive .Rename it 1.apk (Easier to remember)
Path of launcher is now ,C:\1.apk
C:\Android\platform-tools>adb install C:\1.apk
That will give you a launcher to navigate at least :)
Like below
C:\Users\3ndri>C:\android-sdk-windows\platform-tools\adb install C:\1.apk
well im sorry, maybe im doing something wrong here but check it yourself! and thanks again for your time.i really appreciate u trying to help me
:( how should my phone be?in what mode connected via usb? (ex:in usb mode, or system recovery)
Uploaded with ImageShack.us
C: \android-sdk -windows\platform -tools\adb install C:\1 .apk
lines in red represent the command.lines in green the working directory.
the above command should work fine
C: \android-sdk -windows\platform -tools>adb install C:\1 .apk
