so initially a few weeks ago i couldn't do the leaked version of 2.1 due to the fact my Windows Vista would not install driver software.
then when the official came out, i still couldn't do it until one morning i decided to give it one more try and by reading a few forums, found that turning on USB debugging could make it work.
and to my surprise, amazement, and happiness IT WORKED!! i was stoked!!!
i but DE03 on with Joey's Root, Recovery, And custom SDX update.
I was loving it!!!
then earlier today i read about Joeys new Kernal and 3.0.8 recovery which i heard was amazing.. had to put it on!!!
at this time i was running live wallpapers, 3d gallery, handcent, all my awesome apps, nothing much different from 1.5 except i installed
LAUNCHERPRO BETA
which i loved!!!
so on the kernal i made my own SDX custom with a new boot image, new boot animation, HQ youtube, and decided to put one the awesome themes the guys at SDX had on the custom.
i threw it on.
loved it. was amazing. faster. awesome.
then i wanted to see what the new ADW launcher was like that i installed with the theme.
so being an idiot (without thinking of the manage apps option i settings) i just went to the market and DELETED launcherpro beta thinking when i pressed the home button id be takin to the ADW launcher..
WRONG!!!
my phone blacked up. i couldnt go HOME at all. only switch in the market and the alarm clock app i had open. couldnt access settings, pref. nothing!!!
so i pulled the battery out. restarted my phone... and it was stuck at the boot animation for over 15min. i rebooted 4 or 5 times all with the same result. so i tried reboot to recovery, applying my original zip, flashing the kernal, even creating a new CUSTOM sdx update and applying that... nothing!!!
and now when i plug my phone into my computer it wont recognize my drivers!!! it wont even let me uninstall and reinstall my drivers!!!
so after 4hours of extreme frustration i decided to boot to recover and wipe/factory reset...
booted my phone up and loaded to the lock screen. i slid to unlock and it said samsung setup force close and wont let me set up anything. i can do absolutely nothing. im left with a black screen and i can pull down the notification bar and thats it. nothing. black.
im stuck. im gonna loose my mind right now if i cant fix this. if anyone anywhere can give me any help or any suggestions i will be eternally grateful!!!
thank for reading all this and showing interest!!!
I was loving it!!!
LAUNCHERPRO BETA
which i loved!!!
i threw it on.
WRONG!!!
