Root please help me com.android.vending Problem?
helloa
Hi..
I am using HTC wildfire s, i rooted my phone and i deleted some unwanted system apps unfortunately i unknowingly deleted some main files..
the problem is market app is not working its saying" the application market (process com.android.vending) has stopped unexpectedly please try again later"
i installed latest Google play its not working same problem to google play
ANY SOLUTIONS??
Hi..
ANY SOLUTIONS??
Hello helloa.
Do you want to remain rooted? Or do you want to restore the device to factory settings (and then perhaps try rooting again, having learned a bit about what not to remove ;)).
Resetting HTC*Wildfire*S is a site which shows the hard reset methods available for the Wildfire S.
This All Things Root area sticky has some info you should find useful:
http://androidforums.com/wildfire-s...ock-rom-ruu-after-bricking-rooted-device.html
