How are you installing the said files with no recovery? If you have the recovery even though I said I wouldn't help you. I need you to dump something to the sd card.
I managed to get recovery to work. Most of the time it starts to load then reboots. After a while I finally got into recovery. If i try to use fastboot command line i get an error every time i try to flash or boot something. What do you want me to dump?
Edit here is my current log...
Starting recovery on Tue Jan 8 03:07:54 1980
can't open /dev/tty0: No such file or directory
framebuffer: fd 3 (540 x 960)
2FS kingdom CWM Recovery v5.0.2.8
recovery filesystem table
0 /tmp ramdisk (null) (null)
1 /recovery emmc /dev/block/mmcblk0p21 (null)
2 /boot emmc /dev/block/mmcblk0p22 (null)
3 /cache ext4 /dev/block/mmcblk0p28 (null)
4 /data ext4 /dev/block/mmcblk0p27 (null)
5 /sd-ext ext3 /dev/block/mmcblk1p2 (null)
6 /sdcard vfat /dev/block/mmcblk1p1 /dev/block/mmcblk1
7 /system ext4 /dev/block/mmcblk0p26 (null)
8 /wimax emmc /dev/block/mmcblk0p25 (null)
9 /misc emmc /dev/block/mmcblk0p17 (null)
W:Unable to get recovery.fstab info for /datadata during fstab generation!
W:Unable to get recovery.fstab info for /emmc during fstab generation!
I:Completed outputting fstab.
I
rocessing arguments.
W:failed to mount /dev/block/mmcblk0p28 (Invalid argument)
E:Can't mount /cache/recovery/command
I:Checking arguments.
I:device_recovery_start()
Command: "/sbin/recovery"
ro.secure=0
ro.allow.mock.location=1
ro.debuggable=1
persist.service.adb.enable=1
ro.build.id=GINGERBREAD
ro.build.display.id=htc_kingdom-eng 2.3.7 GINGERBREAD eng.home.20120620.013219 test-keys
ro.build.version.incremental=eng.home.20120620.013219
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=2.3.7
ro.build.date=Wed Jun 20 01:33:37 EDT 2012
ro.build.date.utc=0
ro.build.type=eng
ro.build.user=home
ro.build.host=home-EP45-UD3R
ro.build.tags=test-keys
ro.product.model=ADR6350
ro.product.brand=generic
ro.product.name=htc_kingdom
ro.product.device=kingdom
ro.product.board=kingdom
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=HTC
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=msm7x30
ro.build.product=kingdom
ro.build.description=htc_kingdom-eng 2.3.7 GINGERBREAD eng.home.20120620.013219 test-keys
ro.build.fingerprint=generic/htc_kingdom/kingdom:2.3.7/GINGERBREAD/eng.home.20120620.013219:eng/test-keys
ro.cm.device=kingdom
ro.sf.lcd_density=240
debug.fb.rgb565=0
ro.gsm.2nd_data_retry_config=max_retries=3, 2000, 2000, 2000
rild.libpath=/system/lib/libhtc_ril.so
ro.ril.ecc.HTC-GCC=999,112,997
ro.ril.ecc.HTC-WWE=999
ro.ril.ecc.HTC-ELL=92,93,94
ro.ril.enable.a52.HTC-ITA=1
ro.ril.enable.a53.HTC-ITA=1
ro.ril.enable.a52=0
ro.ril.enable.a53=1
ro.ril.disable.fd.plmn.prefix=23402,23410,23411
ro.ril.enable.sdr=1
ro.ril.enable.amr.wideband=0
ro.ril.enable.dtm=0
ro.ril.gprsclass=12
ro.ril.hsdpa.category=10
ro.ril.hsupa.category=6
ro.ril.hsxpa=2
ro.telephony.default_network=0
wifi.interface=eth0
wifi.supplicant_scan_interval=15
mobiledata.interfaces=gannet0,rmnet0,rmnet1,rmnet2
ro.opengles.version=131072
dalvik.vm.heapsize=48m
ro.ril.def.agps.mode=2
ro.ril.disable.power.collapse=1
ro.ril.update.org.acoustic=1
net.tcp.buffersize.hsdpa=4094,87380,393216,4096,16384,110208
net.change=net.bt.name
keyguard.no_require_sim=true
ro.kernel.android.checkjni=1
ro.setupwizard.mode=OPTIONAL
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.factorytest=0
ro.serialno=HT253MB00165
ro.bootmode=recovery
ro.baseband=1.11.00.0418_2
ro.carrier=COMMON
ro.bootloader=1.30.0000
ro.hardware=kingdom
ro.revision=2
ro.emmc=1
init.svc.choice_fn=stopped
init.svc.recovery=running
init.svc.htcbatt=stopped
init.svc.adbd=running
ro.9kramdump=0
I:Checking for extendedcommand...
I:Skipping execution of extendedcommand, file not found...
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
E:Can't mount /cache/recovery/last_log
E:Can't open /cache/recovery/last_log
W:Can't unlink /cache/recovery/command
E:Unable to write to ums lunfile (No such file or directory)W:failed to mount /dev/block/mmcblk0p28 (Invalid argument)
-- Installing: /sdcard/smw6180_superwipe.zip
Finding update package...
I:Update location: /sdcard/smw6180_superwipe.zip
Opening update package...
Installing update...
script aborted: assert failed: getprop("ro.product.device") == "jewel"
E:Error in /sdcard/smw6180_superwipe.zip
(Status 7)
Installation aborted.
Signature Check: Enabled
I:1 key(s) loaded from /res/keys
Verifying update package...
I:verify_file returned 1
E:signature verification failed
Script Asserts: Enabled
Signature Check: Disabled
Script Asserts: Disabled
(Status 7)
-- Wiping data...
Formatting /data...
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 7647
Inode size: 256
Journal blocks: 4778
Label:
Blocks: 305852
Block groups: 10
Reserved block group size: 79
Created filesystem with 11/76470 inodes and 10067/305852 blocks
error: file_write: write: I/O error
Starting recovery on Tue Jan 8 03:39:43 1980
I
ro.secure=0
ro.debuggable=1
ro.build.date.utc=0
ro.build.type=eng
ro.build.user=home
ro.wifi.channels=
debug.fb.rgb565=0
ro.ril.enable.a52=0
ro.ril.enable.a53=1
ro.ril.enable.sdr=1
ro.ril.enable.dtm=0
ro.ril.gprsclass=12
ro.ril.hsxpa=2
wifi.interface=eth0
net.bt.name=Android
ro.factorytest=0
ro.carrier=COMMON
ro.hardware=kingdom
ro.revision=2
ro.emmc=1
ro.9kramdump=0
Formatting /data...
Block size: 4096
Inode size: 256
Label:
Blocks: 305852
Block groups: 10
Starting recovery on Tue Jan 8 03:58:50 1980
I
ro.secure=0
ro.debuggable=1
ro.build.date.utc=0
ro.build.type=eng
ro.build.user=home
ro.wifi.channels=
debug.fb.rgb565=0
ro.ril.enable.a52=0
ro.ril.enable.a53=1
ro.ril.enable.sdr=1
ro.ril.enable.dtm=0
ro.ril.gprsclass=12
ro.ril.hsxpa=2
wifi.interface=eth0
net.bt.name=Android
ro.factorytest=0
ro.carrier=COMMON
ro.hardware=kingdom
ro.revision=2
ro.emmc=1
ro.9kramdump=0
-- Installing: /sdcard/ph44img.zip
I:Update location: /sdcard/ph44img.zip
Block size: 4096
Inodes per group: 7333
Inode size: 256
Journal blocks: 3208
Label:
Blocks: 205311
Block groups: 7
Reserved block group size: 55
Created filesystem with 11/51331 inodes and 6666/205311 blocks
| Welcome to xFuZiiOnZz-4.3.2 |
| by 2fast4u88 and Team |
| Team Consists Of |
| Cookiefrog, Grad and BMaae4 |
Thanks To Mrsboots For The BackUp
* Carrier Detection *
* Magic By: 2fast4u88 *
* TEAM INVICTUS *
Formatting System And Data
E:Error in /sdcard/ph44img.zip
(Status 1)
