Help Please help...menu and back key don't work.
date123
Hello, I have a Samsung Galaxy S GT i9000 and the menu and back keys wont work. I have tried the hard reset and had no luck. It is so annoying using the home key to go back for everything :(.
We got our Captivates/Galaxy S i897 about a month and a half ago. My husband had his replaced already due to the random shutdown problem, mine took a little longer before it was also shutting down randomly every day.
I took it yesterday to a nearby AT&T warranty appliance center and got a replacement (refurbished) phone. This one will, for some unknown reason, get itself into a state where the softkeys (menu, home, back, search buttons at the button) are totally dead. Not an issue with not pressing them correctly, we'd been doing this without a problem. Then, the only way you can get back to home, etc. is to power off. We did a hard reset, problem was still there.
It was like this yesterday, even after the hard reset. Then suddenly this morning, it's fine again.
date123: - Do you remember EXACTLY when the problem started for you??
Just want to ask if the screen protector affects the responsiveness of the menu and back key of samsung galaxy w! cause it take me almost a minute and sometimes i need to press it a little harder ......:mad:
what should i do?
