tabascoz28
FIXED - noob issue. Basically the baseband was too old and I wasn't getting reception.
Hello all... First I'd like to say that I have searched the forum with little results. I'm not an expert rooter/flasher so I probably did something wrong.
I purchased a stock Inc 2 and used ebay to unlock it to use with ATT. It worked for a day perfectly but I wanted to root and get rid of bloatware.
After a few roms, I started to notice I couldn't get a signal anymore from GSM. CDMA or global wants me to connect or set up via Verizon.
When I set it on GSM it immediately goes to no bars and then "no network found". When I try to go to GSM call settings, it says "call settings error: Network or sim card error." I know this is not a setting that I messed up on and it has to be software.
So now I'm down to android 2.3.3 stock Ruu.
RUU_Vivo_W_Gingerbread_S_VERIZON_WWE_2.18.605.3_Radio_1.09.01.0622_NV_VZW1.92_release_199487_si.zip
Anyone have a fix for this? I am still rooted/s-off and have revolutionary recovery. I tried to get rid of that stuff too but the thread deemed it irrelevant.
